03-26-2023
05:06 PM
09:20 AM
my menu window on my mf260 printer came up in chinese and i can not change it back to English.
03-28-2023 07:21 PM
I had to re-initialize. I hit
Menu
3 down OK
down to bottom ok
left button ok
Make sure to put in a PIN when you set it up again
Good luck
03-28-2023 09:57 AM
Hi, marlowe!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. "MF260" can refer to any of several printers in the imageCLASS MF260 series. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
04-05-2023 09:39 PM
Danny ... what you suggest DID NOT WORK!!! I have to get a Technician to fix this brand new printer and it will cost me a Service call ... what's up with that!!???
03-28-2023 05:23 PM
My printer is the ImageClass MFC264 II
Same problem. All menus are suddenly chinese.
Cheers
03-28-2023 07:21 PM
Menu
3 down OK
down to bottom ok
left button ok
Good luck
04-05-2023 09:40 PM
NO .. this does not work ... tried several. times. What pin??
05-31-2023 09:55 AM - edited 05-31-2023 10:02 AM
Thank you so much for this simple and clear post. I advise anyone following these steps to be calm when doing so and to follow them carefully because they DO work for the MF264dw 2 series if followed exactly as written. Tip: on the step that tells you to go to the bottom; please pay attention to the scroll bar on the right of the screen so that you know you are at the bottom of the screen because it will cycle back to the top if you continue to press the down arrow. Also the step where you press the left button and ok, had to be done 2 times. I wish I had thought to record the steps as I did them for the visual people. I am Not yet sure about how to set the pin up after the language is reset. but my issue was resolved for the language reset following these steps. Thank you again for this post
I did do a google search for Remote UI and got a definition of what it was. The search results also tell that there is a default setting for this and recommend changing both. So again I advise anyone doing this to do it while patient or calm and not in a rush.
03-28-2023 07:26 PM - edited 03-28-2023 07:33 PM
If only the printers menus are displaying in another language, you can use the following:
If the remote UI is also displaying in another language this one.
You do not need to reset the printer, just select the desired language. See page 380 if you'd like to take a look.
imageCLASS MF269dw / MF267dw / MF264dw / MF269dw VP User's Guide (c-wss.com)
~R5 C (1.0.5.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw ~Pixel 8 ~CarePaks Are Worth It04-05-2023 09:38 PM
I cannot change it back to English no matter what I do ... Brand new printer .. will now cost me $50 to fix it!! THIS IS INSANE!!
04-05-2023 09:41 PM
Does anyone has a viable solution to fix this Chinese language issue? What you are all suggesting does not seem to work in my world ... before I have to pay for a service call .. thank you to anyone who has a good suggestion!!
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
