10-30-2024 03:16 AM
Hello!
I am using an i-Sensys 4330d for years and everything worked fine so far. Recently, when I am trying to print (single or duplex does not matter), the printer pulls in multiple sheets of paper shortly after another. For example, if I want to print a document with 4 pages in duplex, page 1 of sheet 1 is printed correctly, but page 2 is blank - as are pages 1 and 2 of sheet 2, which comes more or less directly after sheet 1 (shown here: https://imgur.com/a/Yczsy2T). You can see that the mechanism which lifts the paper is working several times instead of only once per sheet.
I get the question on the device if I want to use the recent format, yes/no, but choosing yes, the same procedure as before begins. Choosing no, it tells me to load the correct paper.
I used different PCs and various sheets of paper with different thickness and with different print settings but to no avail.
I would be very happy about every advice and help! Thank you very much in advance.
11-01-2024 09:00 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
