10-17-2017 08:45 AM
When I make copies and print documents in my Canon Mf9200 series ufrii lt is starting to produce dirty pages, the front and the back of the papers are dirty , i tried to change the cartridge but the probleem remain , also i noticed that a bove the cartridge is very heat more than normale and i see small black plastic or some matriela above the cartridge , any help would be appriciated ,thanks
10-19-2017 04:14 AM
Hi Mahmoud1,
I recommend cleaning the fixing unit. If black streaks etc appear on printed output, the fixing unit may be dirty. Also, you should use the Fixing Unit Cleaning procedure every time the toner cartridge is replaced. Print the cleaning pattern on LTR paper for cleaning the fixing unit.
NOTE:
1. Press
(Main Menu).
2. Press the right Any key to select <Additional Func.>.
3. Use [
] or
(Scroll Wheel) to select <Adjustment/Cleaning>, then press [OK].
4. Use [
] or
(Scroll Wheel) to select <Fixing Unit Cleaning>, then press [OK].
5. Confirm that <Start Cleaning> is displayed, then press [OK].
Printing starts.
Discard the cleaning paper after use.
NOTE:
The cleaning process cannot be canceled. Please wait until it is completed.
6. Press
(Main Menu) to return to the Main Menu screen.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
10-26-2017 03:23 AM
Thanks for your reply , i will give it a try , i will let u know if it work,regards
