02-25-2017 01:20 PM
I have an MB2350 installed with Wi-Fi in windows 7 and it's working. I have setup received faxes automatically stored to a USB thumb drive. How can I go sift through the received faxes and see which ones I want to print directly from the PC. I mean without : manually; disabling the automatic save to USB Drive setting, then removing the USB drive, then plugging it in to the PC, then running explorer, then sifting through the PDF files etc. Thanks
02-25-2017 02:23 PM
Hello.
To ensure that the data on the thumb drive is not corrupted you would first have to manually turn the Auto Save Setting off and perform the process that you mentioned.
There is no way for the unit to selectively reject certtain faxes or allow you to view them from the display. You would have to turn the save setting off and disconnect the drive and perform the process that you normally do.
02-25-2017 02:23 PM
Hello.
02-25-2017 02:32 PM
Thanks for your answer Michael.
I quess the answer is no.
Regards
