11-15-2017 04:12 PM
11-16-2017 01:08 PM
Hi ll38ymrn
So that I may better assist you, I will need some more information about your situation. Do you mind answering a few questions?
(1) How are you connecting the mf628cw to your computer, with a USB cable or via your network?
(2) Does the light stop flashing after resetting your MF628Cw using the steps below? If not, what exactly is displayed on your printer's LCD screen?
1. Turn the printer off with the Power button.
2. Disconnect the data cable from the printer (not applicable to WiFi).
3. Unplug the printer's power cord for at least ten minutes, and then plug it back in.
Note: If the power cord is plugged into a surge protector, it may be necessary (for testing purposes) to plug the cord directly into the wall outlet if possible.
4. Turn the printer back on.
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
11-17-2017 11:51 AM
11-17-2017 12:42 PM
04-06-2019 02:56 PM
Sorry this response is so lat but I recently had this problem myself. I turned off and unplugged the printer. That did not work. When I turned the printer back on the blinking light started again. I updated the drivers. That did not work.
As it turns out, the blinking light had nothing to do with the printer. Apparently this issue arose because I have a router with a lower and high speed internet connections. If one isn't working or slows down we just use the other. However, my printer is only uses the lower speed connection. This connections was down and not functioning properly. I overlooked it because the higher speed connection was working. I simply unplugged the router for a couple of minutes, plugged it back in, and gave it a few minutes to start functioning properly. The light disappeared and I was able print immediately. Hope this helps.
01-27-2020 12:42 PM
