06-30-2025 03:18 AM
I'm having ongoing issues with my Canon Color imageCLASS LBP674Cdw. Print jobs show up in the queue but stay stuck in a “Waiting” state and never print. The only indication of any issues in the printer menus is that the color toner cartridges (which are the initial starter cartridges that printer came with) are at 40% and there is a message telling me to prepare a cartridge. I'm not sure how to clear that notification I don't wish to sign up for auto refills I already ordered replacement high-capacity toner cartridges. But there still should be 40% left right? So why is it refusing to print jobs and they get hung up in waiting state?
I have tried the following already:
Has anyone else run into this with the LBP674Cdw? Any ideas what else I could try, or is there a hidden setting I might be missing? Is it related to the 40% prepare a cartridge (Canon Cartridge 069 Toner) message? This is so annoying and not very intuitive as to what the issue is.
07-02-2025 06:25 PM
stupidest thing I ever heard of... Turn off Dept. ID Management which apparently is restricting the number of prints at specified toner level.
07-01-2025 06:52 AM - edited 07-01-2025 06:54 AM
If you have the toner status utility installed, you may remove it. You shouldn't be getting toner warnings for 40% capacity remaining.
Can you please tell us exactly which drivers you installed and are using? The behavior you describe sounds like the driver installed is incorrect or incomplete.
However, it may also be your network configuration. Do you have a static or reserved IP assigned to the printer on your network?
07-01-2025 08:23 PM
[Windows 64bit] Generic Plus UFR II Printer Driver V3.20
07-02-2025 06:25 PM
