11-28-2025
05:13 PM
05:34 PM
SamanthaW
Just purchased a MF273dw laser jet and scanner
Downloaded the Canon MF Scan Utility but when I try to open it the box says no available scanner found.
I can readily print but cannot scan.
Help
11-28-2025 06:08 PM
We need a little more information please.
How is the printer connected and to what?
What operating system version and build are you using the using the printer with?
What software did you install besides the MF Scan Utility?
We can provide next steps when you reply.
11-28-2025 06:40 PM
It’s connected via wireless LAN. It’s the latest version of Apple Mac’s laptop IOS type update. I haven’t installed any other software.
11-29-2025 05:43 AM
Is that latest available for your hardware or Mac OS Tahoe?
Support portal for your product:
https://www.usa.canon.com/support/p/imageclass-mf273dw#idReference%3Dsoftware-drivers
Choose downloads , your OS and install all available drivers and utilities. If you are using AirPrint, you will not get full functionality from your device.
11-29-2025 11:12 AM
I downloaded all drivers. The scanner one takes me to the above screens on driver and asks me to do easy connect to pc.
when I try to “apply” settings it does something. But then I cannot still scan nor print. I have to then shut off printer and reboot essentially and then I cannot still scan print. So probably will just leave it like that. Don’t scan often but if I need to I will just take photo and send it on.
11-29-2025 04:34 PM
You need to look at the printer's networking settings and info to see if it has a valid IP address on your network.
Did you install the printer driver as well as the scanner driver? Can you print to it?
