No Model number
clayrp
There is no model on front or top at all. The only thing I have found is a small tag on the back, again no model number. I'm trying to download win 11 scanner drivers for it. I have found that my computer calls it mf110. How do I find the model number?
3 REPLIES 3
Moderator
Moderator
Hi, claryp!  It sounds like you might have a Canon laser printer that's part of the MF110 series.  Canon USA offers a printer in this family as the imageCLASS MF113w.
If the printer above matches yours, you can find everything you need for it right here.
Hope this helps!
clayrp
That helps, the word imageClass is no where on this printer/scanner.
If the printer in the graphic above matches yours except for the absence of the "imageCLASS" logo seen at the lower right, then it's possible you may have a printer that was intended for a market outside of the United States.  While it may have a lot in common with the imageCLASS MF113w, it might not necessarily be a perfect match, especially in regards to the printer's power requirements and the toner cartridges that it uses.  Please keep that in mind.
Glad we could help!
