01-27-2025
06:00 AM
10:40 AM
I have a new GX2020 and have only printed about 10 pages in black. I look at the ink level in the front and it appears like it's 3/4 full. I've not altered the settings from the factory.
Should i leave it in Auto Off, because after 240 minutes the printer completely shuts off. I print occasionally maybe once a week or two. When I turn it on again, it seems to run doing something for about 30 seconds.
Suggestions?
01-27-2025 12:44 PM
Yes, I can contact Cannon, but I need a more detailed response addressing this issue of things to try, settings to check and maybe change, etc.
01-27-2025 12:53 PM
Hello!
If you're worried about the amount of ink your printer uses during maintenance cycles, the best course of action is to contact support. They can assist you with troubleshooting over the phone and help determine if your printer is functioning properly. You can find all your support options in your My Canon Account, including one-on-one phone support, at https://canon.us/account.
01-27-2025 01:11 PM
OK - I'll try this suggestion to contact Cannon directly. I could not find the link to contact them directly on their site, but I'll try this link to see if I can obtain a human being from Cannon to respond. It seems like one has to go through multiple useless AI Bots to obtain a response.
Thank you!
01-28-2025 08:15 PM
OK, so should I let the printer cycle off after 240 minutes OR should I alter that setting to prevent it from totally shutting down and have it on standby ALL the time.
If I have to allow the printer to go through these cleaning sessions a lot of ink will be wasted needlessly,
That is my concern.
