GX2020 Queue says print job successfully sent, but there is no printing.
edwardsebesta
ONLY ANSWER IF YOU HAVE HAD THIS PROBLEM.
I reinstalled the drivers and restarted the computer.
The GX2020 showed up and I sent a print job to it. The queue said it was successfully sent. Also, I did the print test job and it was successfully sent. However, no printing occurs, there isn't any noice.
Yes, the cable is connected and I have powered off and on the printer.
The scan utility works. The printer is connected to a UPS which is connected through a surge protector.
It seems GX2020 breaks down quickly. This one was purchased 3/18/2025. I remember the prior one didn't last long. Too bad, when it is working it is fairly good.
0 REPLIES 0
