Duplex printing choice greyed out on MF644 connected via LAN to iMac running Catalina
Schmen
I just attached a brand new MF644 connected via ethernet to my iMac running the latest software (Catalina). When I go to print a 2-sided document, there is no 2-sided option in the "Default" printing preset. When I go to the "Layout" menu the 2-sided option is greyed out. When I look at the print presets, 2-sided prining is turned off and I see no way to change that setting. However, when I go to the "Finishing" option menu on the Print dialog Box, 2-sided printing is an option and it works. So what's going on and how do I get the 2-sided option into the standard print dialog box. Thanks!
2 REPLIES 2
Darius
Whiz
Hello Schmen.
To what size of paper are you printing?  Some sizes do not support automatic duplex printing [reference].
If you need immediate assistance with this issue, please contact us using the numbers and information at http://Canon.us/ContactLI
I'm not sure I saw an answer in there, just more questions. I have the same issue. Double sided printing works from my mac running El Capitan (10.11) but not from another mac running High Sierra. I have all the latest drivers.
