Change size of printer properties window?
BuckyKat
My organization has a Canon C5255 with a Fiery RIP and when you open the printer properties window, you end up with scroll bars on most of the tabs because the amount of options can't be displayed on one screen. This issue is compounded when you open the Job View section at the bottom of every window and have about half the height of the main window now available and even more scrolling to do.
I asked a technician about this and they seemed to think that it may be possible to change the window height from the network server where the driver is installed, but I couldn't find any way to resize the window at all.
Is there some way to resize the window so I can see more options without having to constantly scroll as much?
1 REPLY 1
Moderator
Moderator
Hi, BuckyKat! Thanks for posting!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area!
We hope this helps!
