04-26-2016 01:05 PM
Does anyone out there use a Canon Oce 8750 continuous feed printer (roll to cut) then use Bell and Howell Ascenders for their interters? We are running into an issue with too much toner rubbing off from the printer on to the belts of the Ascender to have that toner then rub off on to the output.
If so, what was your solution (if any)? Thanks!
04-26-2016 01:14 PM
Hi, bdcashmo! Thanks for posting!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER and Océ series products. Instead, your dealer will be able to help you! If you don't have a dealer, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area!
We hope this helps!
