Canon ImageClass MF4890dw will not scan on Windows 10
mbharr
Hello, Any help or reasonable suggestions would be appreciated.  I have a Canon Multi-Function printer (MF4890dw) that prints fine, but I cannot get it to scan.  I've tried removing the printer, installing new drivers, and the Network/USB Scan Patch in every conceivable order that I could think of with no luck.  Here is the general pattern I followed when attempting to get this to work:
  • Remove existing Canon printers and printer software from the laptop:
    1. Delete all pre-existing Canon/MF4800 Series printers from your computer (Settings > Devices > Printers & Scanners, then highlight and hit DEL for each Canon Printer entry)
    2. Delete all Canon MF Drivers and Canon ImageClass/MF Software applications from your computer (Settings > Apps > Scroll down to the Canon apps, click once on the app, and select uninstall.  If the uninstall process hangs, reboot and repeat).
  • Disconnect the USB cable that connects the laptop to the printer (if it’s connected)
  • Install the latest driver from the Canon website:
    1. Go to the Canon website > Support
    2. Enter the printer model number (MF4890dw)
    3. Choose the product support page
    4. Choose the Software & Drivers option
    5. Download the [Windows 64bit] imageCLASS MF4890dw/MF4880dw MFDrivers (UFR II / FAX / ScanGear) file.
    6. Go to your download directory
    7. Left-mouse click the downloaded file (e.g., MF4800MFDriverV4101WPusEN.exe) and select Run as Administrator
    8. Follow the on-screen instructions
  • Restart the laptop
  • Install the Canon Network and USB Scan
    1. Follow steps 3a – 3d.
    2. Download the [Windows 32-bit & 64-bit] Patch for Network Scan, USB Scan file
    3. Go to your download directory
    4. Double-click the downloaded file (e.g., NetworkUSBScanPatchEN.exe)
    5. Follow the on-screen instructions
  • Restart the laptop again
  • Add the printer.
    1. Connect the USB cable to the laptop from the printer.
    2. Go to Settings > Devices (Bluetooth, printers, mouse) > Printers & Scanners
    3. Click Add a printer or scanner
    4. Select the Canon MF4800 Series (Multi unction Printer, Laser printer, Fax, Scanner)
    5. Click Add device
    6. Wait for the laptop to connect and install the printer
    7. Select the printer and choose Print a test page.
Restart (not reboot) the laptop again
Scanning still does not work.
I've tried installing the MF Toolbox but it does not recognize the printer as a scanner.   This is the message I get:
3 REPLIES 3
mbharr
I should mention that I get the same message when using the Windows Scan tool.  I've also tried installing the printer before applying the USB/Network Scan patch with no luck.
Moderator
Moderator
Thanks for letting us know what Canon product you've got. The imageCLASS MF4890dw is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
mbharr
Thank you for the reply, although I hoped there would have been a resolution to the issue.   Interestingly, I have a second laptop with a fresh install of Windows 11 and the printer works as designed over a USB connection (at least for print and scanning) with only the Canon driver installed.
