05-03-2026 09:48 AM
I am having trouble re-installing drivers for my Canon MF656Cdw printer. While trying to fix a problem with not being able to scan from the printer, I caused an error in regular printing. I decided that I needed to re-install drivers but am not able to do so. When I try to install the drivers I get a message saying that drivers are already installed. I then attempt to remove the drivers but I get a message saying that drivers cannot be uninstalled because the printer is in use. However, I have cleared the printer queue so there is no active job. What can I do?
I did an AI search for a solution and received (and followed the steps) the following response:
This is a classic "catch-22" with printer drivers. The operating system often flags a printer as "in use" because a background service is maintaining a connection to it, even if no documents are actually waiting to print.
Since you've already cleared the queue, here is the sequence to force the system to release the driver so you can perform a clean re-install.
The Print Spooler is the service that manages all print jobs and driver communication. If it’s running, it may hold a lock on the driver files.
Sometimes "ghost" files remain in the system folder even after the queue looks empty in the UI.
Instead of using the standard "Settings" menu, use the more powerful management console to break the "in use" loop.
Canon drivers often come with a specific cleanup tool that is more effective than the Windows Add/Remove programs.
Once the drivers are removed, when you go to re-install:
If you are still blocked, try disconnecting the USB cable or putting the printer in "Offline" mode via its touch panel before attempting the uninstallation again. (NOTE THAT I CAN CONNECTED VIA ETHERNET AND DID NOT TRY THIS STEP)
What can I do to resolve this.
05-03-2026 05:06 PM
This post can be deleted. The problem is resolved. (I don't see a way that I can delete this myself.
05-13-2026 02:39 PM
Hi, Painter-Carver! You might not be the only one who encounters this problem, so to help someone who might find this in the future, please feel free to share your solution.
We look forward to your post!
05-13-2026 04:39 PM
It sounds like you may have given up. If you'd still like assistance, I'll be happy to help you.
Just reply back to this thread and we can pick up where you left off.
