12-10-2020 06:37 AM
Hi, I have MF8280CW and i installed printing driver and added printer als "Bonjur" type and ewerytching working fine thru WiFi connection. Then I installed scanner driver, and when I'm try to run it (MF Toolbox) instantly im getting error message that it can't find scaner. It's the same when I'm trying to run "Canon MF Scan Utility", I'm getting error message, but it let me to add scaner but dont find any from "bonjur" type and when I'm try whitch "IP" and put correct ip adress I'm getting "This scanner is not supported"
What can i do ??
Operating system: MacOS 10.13.6
Drivers:
File version: V10.11.6
Release date: 09 December 2020
File version: V2.15.6
Release date: 07 December 2020
12-10-2020 09:43 AM - edited 12-10-2020 09:46 AM
Not sure what drivers you are running or where they came from?
For HighSierra (10.13), I see the following are available:
Support | Color Laser | Color imageCLASS MF8280Cw | Canon USA
The drivers you have seem to be newer. Not saying they won't work, but these are not listed on the Canon USA website for your printer model.
12-10-2020 10:13 AM - edited 12-10-2020 10:15 AM
Tey are from official site: https://www.canon.at/support/consumer_products/products/fax__multifunctionals/laser/laserbase_mf_ser...
12-14-2020 07:04 AM
No one can help me ??
