01-31-2020 09:57 PM
I have a simple request. If you're going to remove a post, then you should send the user an email and say why the post is being removed, especially if the reason isn't obvious. This is a courtesy and also good practice. Because you can't expect someone to correct a mistake if you don't tell them what it is.
Thank you.
From the forum guidelines:
We may remove posts that could be considered:
If violations to these rules are severe, or they continue after warnings, a user's privileges to the Forum may be suspended for any length of time, up to and including a permanent ban, at the sole discretion of Canon USA.
