02-15-2017 09:38 AM
They all look pretty good on paper, except for one thing. Battery capacity. All three use the same battery, LP-E17. I don't think giving the 77D a small battery was a good idea.
05-25-2017 10:57 PM - edited 05-25-2017 11:04 PM
@Harhutch wrote:Anyone aware if the T7i has a battery grip available yet?
Hi Harhutch:
To the best of my knowledge Canon have not made battery grips for their Rebel series for quite a few models - the last I recall having one was the Canon 650D (Rebel T4i). You might be able to get a 3rd party grip. It appears that Canon have reserved grips for the XXD and XD models.
05-26-2017 08:44 AM - edited 05-26-2017 08:45 AM
Thanks. I have battery grips for my T3i and T4i just want to know about T7i before I get one.
05-26-2017 05:11 PM
@Harhutch wrote:Thanks. I have battery grips for my T3i and T4i just want to know about T7i before I get one.
I do not foresee a grip for the T7i from Canon, because the battery compartment seems to lack the extra contacts needed for a shutter button and other controls. The T5 and T6 were the same way, and Canon did not release grips for those bodies.
A couple of third parties released grips, but the shutter control on the grip was a wire that went into the wired remote shutter port on the side of the camera. The external wire could be removed, and you simply had extra battery power.
08-11-2017 08:02 PM - edited 08-26-2017 04:01 AM
Was freaking out about this cause I just bought the 77d thinking they would def have a battery grip. DOH!!
But after an hour of internet search I found the answer with a Travor grip model BG-1X on a famous auction web site. It has a tiny headset size male to male cable that lets you use the shutter in the vertical mode. The best case scenario given the fact that they only have 4 contacts in the battery compartment. Got my 2 new Oaroda batterys that the camera can get the remaining battery life even with the 2 batteries loaded in this grip. STOKED!
Cmon Canon, let us peasants with plastic cameras have a plastic grip to match!!!!
08-12-2017 06:46 AM
@beachmiles wrote:Was freaking out about this cause I just bought the 77d thinking they would def have a battery grip. DOH!!
I hope that you did not buy one. The only third party brand of battery grip that I would trust is Vello, and they have not released one for the 77D yet, as far as I know.
Do not bother with using the external wire for the shutter, because it makes the entire setup a little to fragile, and too vulnerable to accidents. This is why having control connections inside the battery compartment becomes important Use the grip only for the extra battery power, because that is really the only purpose for which it is useful.
08-12-2017 09:37 AM
I have a couple of battery grips from Travor and they seem to work fine. The ante has upped recently, at least for the 80D and 7DII, as they seem to figure out that you have a compatible grip and display disouraging messages. For the 7DII I used a Mieke grip and it worked perfectly!
08-26-2017 04:06 AM
I bought one and am very glad I did. It connects up perfectly and works with my 2 QAproda batteries and the camera shows the remaining charge. It only complained about the batteries the first time I turned the camera on with the setup. After that its been smooth sailing.
Since there is no other option availiable I would say this works, feels fairly well built, and a decent price. If there was another option I can't imagine it being too much better than this one.
I prob won't ever use that cable, but if the rare case comes up I'll have it in my bag.
