05-14-2025
10:21 AM
10:22 AM
James_C
Hello!
Can anyone recommend the best RF lenses for Canon R50 for Close Range Event Photography and Portraits and Landscapes?
Basically I need to shoot crowded events and people at events with distance between the camera and subjects sometimes at around 5 feet...
I am looking at the Canon RF 15-35 but would like professional suggestions.
Thank you!
05-14-2025 10:34 AM
That would cover your wide angle needs, but that can be a bit too wide for portraits. I'd recommend the RF 24-70 instead if you need a single lens for now.
05-14-2025 11:11 AM
Thanks Ricky!
I was looking at the 24-70 but on the R50 it seems like it will have to put considerably more distance between the subjects and the lenses. Does this sound correct?
C
05-15-2025 10:20 AM
"Does this sound correct?"
Yes it does. Ricky probably was thinking a FF camera instead of the R50 and the 24-70mm would be perfect for it.
Canon has a R50 kit. The EOS R50 Mirrorless Camera with 18-45mm and 55-210mm Lenses kit would be perfect for what you want. Canon creates these camera/lens kits because they know what is the best for all around photography that most folks do. Did you not get your R50 with a lens? If not look at the two listed above.
05-15-2025 10:28 AM
Hi EB,
Thanks for the reply.
Yes, I do have those lenses however I'm looking to move into the more professional lenses with stabilization and better optics.
C
05-15-2025 11:02 AM
"I'm looking to move into the more professional lenses with stabilization and better optics."
That makes the answer and solution simple. Simply look for R series lenses in those same, or close to, focal lengths. The R series lenses with the "L" designation are the best Canon has to offer.
05-15-2025 02:22 PM
Thank you!
C
