09-03-2026
04:22 PM
04:25 PM
whats the best lense for my eos 2000d
Hi, so i have my camera and i got a 2.2x telephoto lense on my kit lense but i get a ring around the image when i zoom in to much. whats the best lense to shoot nature on that camera, ive tried trying to find a new telephote and wide angle lense but im very lost. also anyone got tips to shoot better animal and nature pictures. i know a better lense would help and i just have no clue what to get.
09-03-2026 05:17 PM
Xee, hiws it going? Welcome to the community.
You mention two different genres of photography animal (wildlife) and nature. Nature is a fairly wide open description so I will assume landscape since you are looking for something wide.
For wildlife you'll need some reach and something like a 150-600mm would be a good purchase for animal/wildlife. Sigma has the affordable C and Tamron has the G2, both will treat you well.
Having a APS-C sensor you may want to take a look @ BH Photo, KEH or MPB to see what is available. Currently BH photo has a very good condition Sigma 17-50mm f/2.8 EX DC OS HSM Lens for Canon EF-S that is a decent lens.
Other will most likely drop in to offer further assistance.
Good luck with your research.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
09-03-2026 10:01 PM
What is your budget?
09-04-2026 11:25 AM
The recommendations my colleagues have made are spot on.
The only thing I can add is this dump the 2.2x lens, converter, adapter, whatever it is, it's low quality.... To put it nicely.
I understand you're working with an 8 yr old camera, but in order for it to give you consistent results, you need to pair it with a higher quality lens. Sometimes the lenses in these less expensive "cheaper" optics are plastic. Other times they are glass which is better, but they still won't perform as well as a quality lens would. I promise you will see the difference immediately. Your camera will thank you too!
09-08-2026 04:06 PM
okay thankyou!! the thing is when i shoot with my current telephoto lense if i zoom out to much i get a black riung around my photo. and im wondering what lense i should have for shooting sunsets. also how do i get my pictures to be less overexposed, cause whenever i shoot a sunset the sky is always stupid bright or the foreground is black.
09-08-2026 04:06 PM
max of 3 to 400
09-08-2026 04:07 PM
so what adapter or whateve should i get?
09-08-2026 04:10 PM
This is a camera problem. not a lens problem. Your camera may have a special sunset setting, or you can reduce the exposure (make the picture darker) a few stops.
09-10-2026 11:55 AM
ok, thankyou. whats the best mirrorless camera under 600? or what camera should i get i want to shoot higher res pics and better quality and i know my cameras not made for that.
09-10-2026 12:21 PM
600 whats? In any case, your camera 200D/T7 should be perfectly fine, I shouldn't have said that it is a camera "problem" more like a camera "setting" It is very easy to add exposure compensation on the T7:
Note the * at the top? That means this does not work in A+ mode, but it does in P.
