09-03-2024
11:13 PM
11:30 PM
StevenMOD
All,
Asking for advice on the above lens. I have a EOS R10 and have been looking for a longer focal length lens than the RF 100-400MM lens that I have. I have an opportunity of buying a RF 600 MM F11 IS STM lens that has had very little use. The only prime lens that I have is a Sigma 500 MM lens. I have very little experience using prime lenses. I would be using this lens at the beach to shoot pictures of birds. Is this lens worth purchasing? Thanks in advance for your response.
09-04-2024 11:40 AM
"Sigma 500 MM lens."
What Sigma lens do you have from Sigma that is a 500mm tele? Sigma made an excellent 500mm f4 but it is very expensive. If you have one you are lucky indeed.
"I have very little experience using prime lenses."
There isn't any difference in using a prime except you can't zoom. Today (subject to change as new lenses come out all the time) still my best recommendation for this type lens is the Tamron SP 150-600mm f/5-6.3 Di VC USD G2.
09-04-2024 11:40 AM
Alex,
Thank you for your comments. In my original post I put 500MM. It should have been 50MM. I have very little experience with a prime lens.
09-04-2024 11:46 AM
ebiggs1,
I missed up on my original post. I have a Sigma 50MM lens. I realize a huge difference in focal length. The Sigma 50mm F1.4 DG.
Thank you for your comment. I need to quit posting late at night so I do not make these kind of mistakes. My brain moves faster than my fingers.
09-04-2024 11:58 AM
OK that clears that up. The big Sigma 500mm f4 lens is a fantastic lens one to drool over for sure. But the Sigma 50mm f1.4 Art is also a fantastic lens. Perhaps the sharpest, at least 50mil, made or ever made. Not to belabor the topic but the Sigma 35mm f1.4 Art is the sharpest lens made, IMHO, of course. And in my job and now my hobby there have been lots and lots of lenses. Hundreds!
For you, I still suggest you check out the big Tammy zoom. Make sure it is the G2 model because the first model isn't all that good. Its OK but the G2 is in another class in several specs.
09-04-2024 05:45 PM
ebiggs1
Thank you for your comments and suggestions. They are very helpful.
04-15-2025 02:40 PM
Just a heads up. I have the Tamron SP 150-600mm F5-6.3 Di VC USD G2 EF and use it with my R10. I was not aware of just how big this lens is. It's a heavy weighted lens at 4.4 lbs (2kg) and I highly recommend a tripod/monopod. You can shoot handheld but the weight catches up to rather quickly.
That being said, ebiggs1 is 100% correct that it is a fantastic lens, and you can't go wrong with it. For me, I'm looking at the 600mm F11 simply for the fact that it's a lot lighter and will be easier to shoot handheld. I use the Tammy mostly for jet spotting now.Tamron 150-600mm
Captured with the R10 & Tamron 150-600
