EF 400mm F 2,8 L II USM vs RF version for Canon R5 and R6
JEJE12
Hello
I am am amateur wildlife photographer and I was wondering if anyone has experience using the EF 400 2.8  L II USM with the R5 and or R6. Obviously I would prefer to buy the RF version of that lens but it is simply too expensive for me. I could also rent it when I go on trips but I figured that if I go to Africa once a year and Montana a couple of times a year, I could probably buy a used EF 400 2. 8 instead. I own the RF 200-800, RF 70-200 2.8 and 100-500 F4 but the RF 400 2.8 is spectacular and was wondering if perhaps the EF could get me excellent result for a fraction of the cost.. any insight would be greatly appreciated.
13 REPLIES 13
Alternatively and since I do not have unlimited budget, I was planning on using my RF 70-200 F 2.8 with an R7.. Hoping I could shoot most of the subjects within 70-200 range and use the R7 crop function for more reach if needed. Am I wrong to think it could be an alternative? Obviously not as good as the prime lens but still a good option.. no?
@JEJE12 the EOS R7 doesn’t offer a crop function like Full Frame bodies. The EOS R7 is a crop and has a 1.6x crop factor. So there is no need for a crop mode for APS-C lenses.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
SignifDigits
I am personally hoping for a R7 Mark ii or R10 Mark ii (if they add IBIS) in Spring 2026 to pair with my 70-200 f/2.8.  It will still be f/2.8 on an APS-C and have effective range of 1.6x the 70-200.  So, it sounds like a reasonable budget option to me as that's what I'm doing myself.  I hoping for enough pixels on the sensor and frames per second performance to fast storage to photograph the birds nearby with reasonable sharpness and detail.
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using no Adobe products.
March411
I can only answer your question from my perspective JEJE12. The bare minimum I would go if I was taking a trip to Kenya would be a 400mm. Even that may not give you the range/distance you need for some of the wildlife that is out some distance. But I have been know to spend more then I should sometimes, not smart.
That being said, the the RF70-200mm on the R7 would give you an effective equivalent focal length of approximately 112mm to 320mm. Additionally the EF400 on the R7 600mm.
I have used my RF100-400mm quite a bit for wildlife but I had the ability to get closer because the animals were not dangerous.
Bottom line, if the funds are not available you are making a smart decision by not over spending. Use what you own, enjoy the trip, don't put your self in a bad position financially and you will get some great shots with the RF 70-200  f2.8 with an R7. Some shots, maybe not but you can live with whatever decision you make knowing you were smart.
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
