04-17-2014 04:12 PM
any know if there is a Maximum capacity for the Mem cards in the T3 (1100d) camera? was wanting to but a 64gb card but the doc's don't say if the camera will accecpt a card with that much storage...
04-17-2014 08:00 PM
Sorry, can't say for sure. Does the manual say if it accepts SDXC? If it does it should take 64, but SDHC technically is limited to 32 gB.
04-18-2014 08:09 AM
Large SD cards is a bad idea even if the camera can use them. You will tend to fill it more and more because you can. You will have more at stake if something should happen to the SD card. I would prefer, and do use, four 16 GB cards.
If you do lose a card, for whatever reason, at least you won't lose everything you did.
04-19-2014 04:03 PM
^^ This
Memory cards go bad. You'll want to have a few of them. There's also the eventuality that you'll transfer images to your computer and forget to put it back in the camera, be miles from home, and get the dreaded "no card" message.
04-19-2014 06:03 PM
all this I know.... Having been using them for many years... But the Question Remains.... Is the T3 (1100d) capible of accessing and Reading/Writting to a 64gb card... It's not in the manual (that I have found at least).... and I have a need for using a 64 or larger card... would even prefer a 132gb if it would work but the 132gb's note that most cameras will not work with 132gb without firmware updates specificlly for it... I don't want to pay 60 to 130 bucks for a high speed card and find the camera will not read/write to it....
So while I appre all the answers to why I should use smaller cards that is not the question...
04-19-2014 06:08 PM
Thanks.. The Manual states SDHC/SDXC/SD but does not Specificlly state it can read/write to 64gb.... Just was hoping I could get someone that has used such and can Absolutlly confirm before I plop down the over 100 bucks for a X200 speed card.... But appre the feed back... If you hear anything or know of anyone using the T3 if you would pass it along i would really appre it...
04-19-2014 09:31 PM - edited 04-20-2014 05:07 AM
I have little doubt a 64GB Class 10 SDXC High Speed Memory Card 50MB/Sec won't in a Rebel T3. It likely will.
But you are not likely to find any of us "matured" shooters that use them. Most of us have learned the hard way not to.
04-19-2014 09:36 PM - edited 04-19-2014 09:37 PM
04-19-2014 10:11 PM
Thanks... Appre the chart link.. Have seen it but still is not specific and absolute and is for the 600d... but do appr the info... will let this stay open with the hope that someone has actually used a specific high speed 64gb card and can specificlly tell me a card that will work before I dump the cash ... Just bought a coupel of flashes and a new lens so moneys tight and wanted to be absolutly sure....
10-16-2017 02:23 PM
