11-26-2016 10:17 AM
i have a canon rebel t3i. the flash will not pop up under any of the manual settings. we are not getting the general error-05, there just seems to be no response to the flash button. ideas?
11-26-2016 12:52 PM
@jasonmorriss wrote:i have a canon rebel t3i. the flash will not pop up under any of the manual settings. we are not getting the general error-05, there just seems to be no response to the flash button. ideas?
Are saying that the flash pops up and works properly in basic camea modes, just not for any of hhe creative modes? And, that
the little button which makes the flash pop up doesn't work, at all?
11-26-2016 01:03 PM
11-26-2016 01:21 PM
No... button doesn't work at all. We can't get the flash to pop up at all. In any mode.
Make sure that your flash is actually enabled in the menus. You should try to contact Canon Support, if it is still not working.
11-26-2016 04:07 PM
The linkage is dirty. You can try to help, pry, it up when you push the flash button. Then you can clean the linkage with alcohol and a q-tip. If you are not successful in 'helping' it up, you will need Canon service.
