06-09-2020 12:23 PM
Hi friends,
has anyone found a solution with recording a video on 70D and immediatly controlling the audio ? also with
playing it after reocording with sound?
I can control the sound after recording because my external monitor has an earphon unit.
But I want to control the sound while recording. Couldnt find a solution yet.
What annoys me as well is that I cannot control the Mode Dial in the dark. A lightened Dial would be great.
Thanks for givin me attention
Rudi
06-09-2020 02:03 PM
Do you mean like this:
06-10-2020 08:16 AM
Thank you so much for your answer. I know the possibilities the cam gives me, but to get a good quality it is necessary to LISTEN while recording. Also the wind filter doesnt help, if I recognize after the recording that there is too much wind noise.
I need a way to control during the recording process. But thank you for spending your time for me. greetings, Rudolf
06-10-2020 08:25 AM
If you are filming outdoors, it is probably best to use an external microphone with a wind screen, also known as a "dead cat".
06-10-2020 09:28 AM - edited 06-10-2020 09:34 AM
The earphone should work while recording. The camera does turn off the sound when you are recording without headphones to prevent feedback.
Edited to add:
My bad, there is no headphone jack on the 70D. They only way to monitor is to use an external microphone into a mixer and monitor that.
06-11-2020 08:20 AM
Thank you very much. I use the Tascam DR 60D as premixer, but I though there could be a smaler posssibility. I want to care as less as possible with me, because I do a lot of interviews so I prefer as less weigth as possible when I move.
