06-24-2024 09:07 AM
I'm increasingly getting the Error 01 code (The communication between the camera and lens is faulty) with both my lenses, so I'm guessing it's the body. Removing the lenses and putting them back on helps for a few shots, but then it's back to the error.
It seems like I just bought that camera , but I bought it in 2017, so it's 7 years old. It's in great shape otherwise. Hardly any wear, but I've read that getting them repaired is expensive, so I'm wondering if I should bother, or just upgrade to a new one?
06-24-2024
09:19 AM
01:56 PM
Stephen
Is one of your lenses a big, heavy one?
I would say: Upgrade!
06-24-2024 01:39 PM
Yes! I have a 70/200.
06-24-2024 01:48 PM
It is unlikely, though possible that hanging that big lens on the camera damaged the mount. Are you having any light leak issues?
Try pushing up on the lens in the direction of the contacts and see if that helps.
06-24-2024 02:02 PM
Hi Keith:
I see what you are getting at, but I would have thought most people would support the camera with the weight-bearing hand under the lens, or on a tripod mount, and the body is not really heavy in itself.
@STUX: Is that how you hold the camera with that 70-200 attached?
06-24-2024 02:06 PM
@Tronhard wrote:most people would support the camera with the weight-bearing hand under the lens, or on a tripod mount.
Back when I was a tech, that's how I always recommended holding the camera and a heavier lens. Just to prevent any extra stress on the mount.
06-24-2024 02:08 PM
There have been a few times I put it on a monopod without holding the lens.
06-24-2024 02:11 PM
Not noticing light leaks. Could it be humidity? It's been rainy and humid here, but today is dry, and I've tried changing the lenses and turning the camera on and off several times, and haven't had the problem (so far).
06-24-2024 04:34 PM
I assume you cleaned both lens and camera contacts...
06-24-2024 05:02 PM
The cost to repair might be past the point of diminishing returns. I recommend reaching out to Canon to get an estimate. Ask about their upgrade program.
