Rotate, edit image, then multiple exposure
RooDog
I shot a few double exposures I liked. But if I rotate the 1st base image using the camera menu, when I try and use it as a base for a double exposure, It shows rotated when I search for it, but pops back to the origional direction after I chose it.
Is there a way to rotate it after you chose it for multiple exposures?
Thanks, RooDog
3 REPLIES 3
Waddizzle
Download the photos, and process them in a computer.  That's the solution.
Thanks, but I thought I read you can't downlad the image, edit it, the reuse on camera for double exposures? I do the double exposure in camera, not PS. Thanks
Waddizzle
Thanks, RooDog
I don't see where it says you couldn't download images.  I had thought you describing actions in the camera.  Just the same, you can almost anything you want in post-processing.
Friends and Family
