06-07-2016 04:01 PM
I went to use my faithful T3i for some wholesome baby photos... and found it wouldn't work!
No matter what setting, when I press the shutter button, the camera clicks once (closes shutter), then nothing. Silence. I have to turn it off, then back on, just to access anything, and no images are loaded onto my SD card.
What do I do!?
Any and all help is appreciated.
Vayda
06-09-2016 11:54 PM
06-07-2017 12:38 PM
They did not work for me; I am able to take pictures close up, however when I try to take pictures that focus from a distance, I still recieve the message, "Err 01:Communications between the camera and lens is faulty. Clean the lens contacts." I am looking for more suggestions..
06-07-2017 01:51 PM
Hmm. Have you tried resetting ALL the settings back to the factory settings? (it won;t affect your clock etc) If nothing yet, you might want to send it in to see what the deal is. Have you tried calling a Canon Rep? They might have an answer none of us know about. You are everyones eyes on what is going on, so be specific when you call them.
I have had that issue when my settings are all wrong, it won't shoot. So I (cheat) switch to A and see what the camera thinks it should be, go back to M or AV, and set closer to those settings. I ONLY do that when the camera won't shoot. You proly already tried all these things, but just in case.....worth a try.
Best of luck. I hope you can get it figured out. I am still curious about the solution when when you find it.
