08-08-2023 06:35 PM
Rebel T3i Camera Shuts off automatically during movie recording. It does this with all of my memory cards. I just received a brand new SanDisk Class 10 256MB SDXC UHS-I card & tried it several times with the same result. It shuts off after 11-12 minutes. I also made sure that the Power Saving setting was turned off.
08-08-2023 07:43 PM - edited 08-08-2023 07:48 PM
The movie recording stops when the file size gets to 4 Gb in size. You may be reaching the limit in file size. From the manual:
08-08-2023 10:09 PM
Yes, it looks like you can only record about 11 minutes before reaching 4 GB file size at those two resolutions.
08-08-2023 07:06 PM
How long does it record before shutting off? Its internal temperature may be getting too high. It tells you when it is. See page 163 of your Instruction Manual.
08-08-2023 07:16 PM
It shut off at 12 minutes with the brand new card. I'm recording again to see if the warning symbol shows up.
08-08-2023 07:18 PM
The new very-large card may be tempting you to record for too long at a time.
08-08-2023 09:47 PM
I checked the manual for the over-heating indicator. When I did the last recording, there was no over-heating symbol. It shut off at 11:55. I'm running another test now with the file size knocked down to 1280/60fps. It was at 1920/1080.
08-08-2023 09:58 PM
How big are the movie files when the camera shuts off please?
08-08-2023 10:01 PM - edited 08-08-2023 10:07 PM
The file size limit is 4 GB, even at 1280 x 720 resolution. The chart I posted above still says 11 minutes for that resolution, as well as 1920 x 1080.
640 x 480 will give you 46 minutes of recording time, but I think that that is over-ridden by an overall 30 minute limitation per recording.
08-08-2023 10:03 PM
Hi Bob:
Yes, I was heading in that direction, given the OP suggests it shuts down about that time.
08-08-2023 10:09 PM
