08-14-2020 01:30 AM
I cannot get my interval timer (for stills, like for the meteor shower last night) to work on the R5. It works fine on the 5DIV. I've seen others conplaining of this problem, but others say it works fine for them. Canon told me that they have had others complain about this. Anybody else have this problem? Anyone aware of a solution in the works? I can use an external interval timer, but I want to be able to use the one in the camera.
12-11-2020 03:15 PM
@aschlabach wrote:Does anyone know if this has been fixed yet in a firmware update? I just got my R5 and discovered this issue -- super annoying. Thank you!
Why would someone need BBF if they are using the interval timer?
12-11-2020 03:18 PM
12-11-2020 03:23 PM
Oh, geez - not this guy again!
Look, I have BBF enabled 100% of the time, period. Just like every other serious photographer I know. It's a standard part of my camera setup. Always has been for every Canon body I've owned in the last 10 years.
BUT when it's enabled on the R5 - UNLIKE EVERY OTHER CANON BODY - the Intervalometer does not take pictures.
AND The intervalometer has ONE JOB: take a picture every XX seconds. When it doesn't take pictures, it's BROKEN, period.
Let me ask you a silly question in return - WHY would you EVER want the Intervalometer to run AND NOT TAKE ANY PICTURES?
12-11-2020 03:29 PM
Oh, and YES - it does appear to finally be fixed in Firmware ver 1.2.0, released on 11/19/2020.
I just installed it, and tried a quick test. IT WORKED. For the first time ever on the R5. I need to do some more testing to be certain in all cases, but it looks like they finally got around to fixing this bug.
12-11-2020 03:34 PM
12-12-2020 12:40 AM
Yes, the 1.2.0 update fixed the interval timer problem, even though they said nothing about it in the description.
12-12-2020 12:52 PM
@aschlabach wrote:
Awesome thank you @jimre! Can you report back after using the camera for a bit? I saw somewhere that someone started having focusing issues after updating firmware, so I've been scared to do that because right now my focus is AMAZEBALLS.
Everything seems to work fine for me with 1.2.0. I can FINALLY use the built-in Intervalometer without having to re-configure my standard camera setup that I've used for 10+ years (which includes "back-button-only-focus").
I haven't noticed any change in focusing. Eye AF is still amazing as ever. I haven't seen any discussion of firmware-related focus issues - do you have a link?
12-13-2020 12:37 PM
