R5 Inconsistent auto ISO bracketing exposures
yellowalien
Camera is set up for auto ISO bracketing (change EV by adjsting ISO instead of shutter speed or f/stop): exposure mode is M with e.g. shutter speed to set e.g. 1/200 s and aperture at f/8. ISO is set to auto ISO (auto ISO range set to 100-6400).
Occasionally I see inconsistent exposures, i.e. two or three exposures that look almost identical in EV, then a jump that looks like more than +1 EV (more like +2 EV) when compared to the previous exposure. I have had a suspicion that this odd behavior might occur near the limits of the auto ISO range.
When using bracketing with shutter speed the exposure brackets look ok.
Has anyone seen this?
9 REPLIES 9
rs-eos
What is the ISO value you are setting for your middle/standard exposure?
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
The camera has firmware 1.3.1.
Looking at a specific example:
EV -3: f/8 1/640 ISO 200
EV -2: f/8 1/320 ISO 200
EV -1: f/8 1/250 ISO 320
EV 0: f/8 1/250 ISO 640
EV +1: f/8 1/250 ISO 1250
EV +2: f/8 1/250 ISO 2500
EV +3: f/8 1.250 ISO 5000
Exposure #5 (EV +1) looks identical (visually) to exposure #6 (EV +2).
Therefore exposure #5 appears two stops brighter than exposure #4.
So the metadata being reported for the EV+1 and EV+2 both show f/8 1/250 and just the difference being in ISO?   I'm assuming no flash is being involved.
What happens if you put the camera on manual, take one expsoure at f/8, 1/250, ISO 1250 and a second exposure at ISO 2500?  Same problem? Or only when bracketing is involved?
Ricky
I'll see whether I can reproduce the problem, and then follow up with manual exposures to go along with it, but as I said, I only see the problem sometimes. The example above was out in the field three weeks ago on an overcast day in the park.
BTW, the next sequence that day also has exposure #5 too bright, but the sequence immediately after had the exposure #6 too bright (same appearance as exposure #7).
EV 0: f/8 1/125 ISO 320
EV +1: f/8 1/125 ISO 640
EV +2: f/8 1/125 ISO 1250   <-- too bright
EV +3: f/8 1/125 ISO 2500
Seems I dropped the shutter speed by one stop to achieve a lower ISO (for the third sequence).
Not a problem that I can see in the numbers.  BTW, if EV +2 is too bright, then why isn't EV +3 a;so too bright?
Why are are using ISO to bracket exposures, instead of shutter speed, anyway?
"Fooling computers since 1972."
When I wrote "too bright", I meant to say, too bright for EV +2 (it appears identical in brightness as EV +3, which I think has "proper" brightness for EV +3 in the example). If you read the first post, the "improper" or too bright" frame isn't always the same.
As you should know, bracketing the shutter speed has implications on motion (blur). But this is beside the point as I am using (or intending to use ISO bracketing.
Maybe I can do some more testing on Sunday, but I have only seen this behavior with auto ISO bracketing so far. I expect manual bracketing to produce "proper" EV -3 .. EV +3 exposures.
Seems nobody has experienced this problem
Because people prefer motion blur over noise, I guess.
When bracketing though, it's much easier to composite images when any movement is at a minimum.
It probably wouldn't matter though depending upon the subject if the shutter is say 1/250 or quicker.   It would though be problematic to composite certain subjects with 1/30 through 1/500 shutter.   You'd end up with much larger areas of movement and that can lead to very poor compositing results.
What I personally do if I can, is bracket with flash power.  Here, aperture, shutter and ISO are now constant.
Ricky
What motion blur?  Normally, you're not trying to capture a bracketed shot of a moving subject.  Isn't a bracketed shot supposed to be that of a static subject or scene?
