01-06-2017 12:14 PM
My 32GB memory card seems to have a problem lately. The first problem was some of the photos I took one day were unviewable, and the second problem is it takes a couple of seconds (10 seconds at least after taking a shot) to proccess to photo. I've switched back from my 8GB memory card to this and the first problem seems to be gone (for now), now it just takes a while for the memory card to proccess a picture. I've never had this issue before. Any advices on how to fix it ?
Thanks in advance !
01-06-2017 12:33 PM
Hmmm, looks like a new SD card is in your future. Ditch it and get another. Don't fool with it, it ain't worth it. Only buy the best name brand SD cards like Lexar and Sandisk or Transend.
01-06-2017 12:55 PM
Did you change some setting that might cause extra processing time? Dark field noise reduction? in camera HDR?
01-06-2017 02:26 PM - edited 01-06-2017 02:26 PM
Sounds like that card has become unreliable. Toss it in the garbage. Buy name brand cards. Only buy full size cards, not the microSD cards with the adapters. Don't forget to do a low level format on the card, in the camera, before using it.
01-07-2017 07:07 AM
01-07-2017 01:37 PM
01-07-2017 02:12 PM
@idanidan123 wrote:
The thing is that I always buy from SanDisk on eBay. The 32 GB I got is from eBay. Do you think there's another reason for it ? Because the brand card is not the issue, I think. I don't buy stuff like this from unknown brand names.
Go find a Best Buy, or some other local electronics store, and buy a new SD card. Your current card is suspect.
01-07-2017 03:52 PM - edited 01-07-2017 03:56 PM
@idanidan123 wrote:
The thing is that I always buy from SanDisk on eBay. The 32 GB I got is from eBay. Do you think there's another reason for it ?....
It's possible the card is a fake. In the past there were A LOT of counterfeit memory cards sold on that auction site.
And the most commonly faked by far were Sandisk.
If you search eBay support, there used to be an extensive discussion there about the fakes and how to tell them apart from the real deal.
Another thing... Do you regularly format your memory card in your camera? If not, you should. That might solve a lot of problems. I format my memory cards first thing, every time I swap out a full one for an empty one (actually, the "empty" one is still full of images from the last time it was useed).
Just keep in mind that formatting will "erase" existing images. So before you format be sure you've downloaded all the images you want to keep. (Note: Formatting doesn't actually erase the old images, it just allows them to be overwritten).
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & EXPOSUREMANAGER
01-08-2017 08:29 AM
