M6 Mark II Help with internal battery question
djjoonie
Hello all, i have m6ii but the date and time resets every time i swap the battery. if i swap it within a sec, it doesnt reset sometimes. So my question is how come it only resets the date and time if its the internal memory battery that is not working? the wifi, bluetooth settings and all my camera settings are all intact even if i leave out the battery for much longer. I already tried the clear all settings on p mode m mode video mode etc. please help! thank you!
14 REPLIES 14
krahe
Rising Star
Rising Star
I think most devices that can handle being without power for a short time have a small, internal battery to maintain essential functions, like remembering settings and keeping the TOD clock updated. However, if that battery goes bad, then even those basic functions are going to start failing. It sounds like that might be what you're encountering. In some devices these are basically watch batteries that can be changed by opening up the device. But I have no idea what the M6 has. (Or any modern camera, for that matter.)
Kevin Rahe
EOS M50 Mark II
AlanRamirez19
Did you solve the problem? I have the issue with my m6 mark ii
EOS M6 mark II loses time/date every time I remove the battery. I got cost estimate for more then 400 $ from canon service support. Maybe you know another way to fix issue?
thanks
Ted
thanks
Ted
tadeuszstanczyk
EOS M6 mark II loses time/date every time I remove the battery. I got cost estimate for more then 400 $ from canon service support. Maybe somebody  knows another way to fix issue?
thanks
Anonymous
Not applicable
I remember one forum member fixed a similar issue by resetting all camera settings and custom settings back to default, but I don't remember which camera he had. Maybe worth a shot,
Thanks
Ted
Anonymous
Not applicable
Did resetting to default help your issue?
No,
looks like I have to find the way to charge main battery via usb-c port. To avoid to remove main battery.
thanks
Ted
Friends and Family
