How is it possible to make a 18 m.p. Picture with a canon t31 slr?
welded
Forgive a newbie but when I set my t31 camera to either raw or the highest jpeg settings, the saved pictures properties indicate that the picture is only  5 m.p.
The camera is rated at 18 mega pixil...What gives?
2 REPLIES 2
rchalfan
Jpeg is a compressed format. The camera firmware makes "intelligent" choices to maintain maximum image quality within the 8 bit dynamic range of the jpg file. The exact size of the file will depend on the image itself but will be in the 5-6 MB (megabyte) range when your camera is set to the highest jpg quality.
Raw files, on the other hand, are minimally processed and the saved file will be around 24MB. If you are seeing 5 MB files from what you think is raw, you may be looking at the .jpg file if you set Raw+jpeg. Otherwise I suggest you check the menu "Image recording quality" setting again as it may not be set to Raw.
Recall as well that the file name of a raw file ends ".cr2" while a jpeg file name ends ".jpg".
MegaPixels are NOT the same as MegaBytes. The explination above should clear the file size error up re your thinking the 2 are one in the same.
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
