Help! My Canon EOS 90D randomly freezes
GeeBabe
Help! My Canon EOS 90D randomly freezes, the only way I can get the camera going again is to take the battery out and re insert. Anyone else have this problem? Or know what the issue is? It seems to be getting worse over time.
Thanks
Gee
9 REPLIES 9
ebiggs1
You need to call Canon it needs service. 1 (800) 652-2666
I'm in the UK - but will probably have to take it in - thanks
deebatman316
Are you using any 3rd party items ie lens, speedlite or a battery. If so remove them and try it again. From the factory.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
-Demetrius
Current Gear: EOS 5D Mark IV, EF F/2.8 Trinity, EF 50mm F/1.8 STM, EF 85mm F/1.8 USM, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D
Waddizzle
How are you using the camera just before it locks up?
There are four possibilities.
  1. Bad lens
  2. Bad battery
  3. Bad memory card
  4. Bad camera.
You can test the first three yourself by using a different lens, battery, or memory card.  A bad battery is probably the least likely cause.  Try removing the memory card and lens, and see if it locks up.
Canon lens, Canon battery, Brand new memory card.
I thought the EOS 90D was supposed to be a good camera?! hmm
Are you using full size SD cards. Micro SD cards can cause the camera to lockup. Do you have another lens and battery to test.
-Demetrius
-Demetrius
Full size memory card - thanks for your reply
ebiggs1
"I thought the EOS 90D was supposed to be a good camera?"
It is! 🙂 One of Canon's best, if not the best, crop sensor DSLR camera.
ebiggs1
GeeBabe any thing can fail at any time. It's just the way it is or maybe the luck of the draw. We hope it won't but it happens and that's why there are so many repair shops around town.
Enter for a chance to win!
April 20th-28th
