08-14-2022 09:11 PM
Hello all...
I want to use my R6 for Zoom calls... I installed EOS3 Utility... Video comes up perfect when using the utility... PC sees camera and lists is as Portable Device... OBS/Zoom/WIN10 Camera will not see it... I closed the utility and made sure it was NOT running in the background. I'm using USB-C to USB-C cable and tried multiple posts (back and front). I'm running an Alienware PC. I tried every solution suggested on multiple threads and video's... and notta 😞 I'm frustrated and sad... any suggestions ??
08-14-2022 09:25 PM
One, are you using the EOS Webcam Utility? It is a special device driver, which is separate from the EOS Utility 3 that you would use to download files to your PC.
08-14-2022 09:25 PM
08-14-2022 09:47 PM
Call me chuckle-head... after a few hours trying to solve this on my own... not using the correct app... you fixed my issues in 30 seconds... ./bow Thank you!
