11-29-2015 10:30 AM
I recently tried turning on my T31 and it wouldn't power on. I have two batteries, so I assumed both were dead and placed one to charge. Once the charge light switched from orange (charge) to green (full), I inserted the battery back into the camera and tried again to power on. Nothing. I placed the second battery into the charger, and tried again, and still the camera wouldn't power on. I took the battery out, and set it in the charger again, and it indicated that it needed to be charged again. The second battery did the same thing. Are the batteries simply no longer any good, or might there be something wrong with the camera?
11-29-2015 11:01 AM
Seems like the charger is messed up. It is unlikely both batteries could go totally dead at the same moment, one would probably last a little longer than the other.
Also, it appears the charger has given you wrong readings, saying both batteries are full and then moments later saying both are empty. There is no way a camera, no matter how broken, could instantly suck the whole charge out of a battery. As stated above it is unlikely both batteries failed simultaneously. All that is left is the charger. If the charger is giving bad info, something is probably wrong with it.
I would try again with another charger. if you can borrow one to make sure that is the problem it would eliminate the risk of buying an unneeded charger.
Is the charger real Canon equipment, or after market? The batteries?
11-29-2015 11:04 AM
11-29-2015 12:58 PM
They both use the same batteries.
As you have the friend with the same batteries, you could simultaneously see what happens using a different battery as well as the different charger.
12-09-2015 08:49 AM
04-18-2016 01:23 PM
Did you ever find out what was causing this? I am having the same issues with my Rebel T5
Bab
04-18-2016 01:34 PM
@hannas2 wrote:Did you ever find out what was causing this? I am having the same issues with my Rebel T5
Bab
Be sure to stick to using a full size memory card, with no adapter. Stick to 32 GB, or less, too. If you do not install a memory card, does it turn on?
04-18-2016 01:43 PM
Both cards I tried were 64 bits, I do have a 32 I can try when I get home from work today and let you know.
Thanks,
Bab
