EOS RP with RF 70-200mm F2.8 L MF/AF setting in camera?
migEOSRP
Enthusiast
Is there a setting in the EOS RP camera which can completely disable the AF, equivalent to sliding the switch on the 70-200mm lens? Some posts refer to this in the Shooting settings 7 and 8 but I don't see an MF/AF setting there.  (I understand how to use all the AF settings in 7, 8 to enable MF during AF mode).
deebatman316
The menu option to set the lens focus mode only applies to RF lenses without the AF/MF switch. Since your lens already has the AF/MF switch those options won't appear in the menu.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
3 REPLIES 3
I would strongly suggest you read the manual for your camera.  👀
EOS RP Manual https://share.google/YA2RNOeQdNxvbR4ax
Put the mode dial to "M" and move the AF / MF switch on the lens to MF.  The camera will then manual focus.
I'm not sure what shooting settings 7 , 8 is?  Maybe this is a menu option.  Can you clarify.
Maybe I'm not understanding your question?
deebatman316
-Demetrius
Thank you. That's what I wanted to know.
