EOS RP Viewfinder Questions
vikarufa
Hello
Could someone answer my two questions about Canon RP?
Manual says that viewfinder and monitor can be set manually.
1. When viewfinder is set as default, when turning on the camera is monitor off, no blinking, turning on and off? Just off?
And if I don't look in the viewfinder when I turn the camera on, is viewfinder also off? Also no blinking on startup, just off?
Is it like this?
Manual also says that I can assign a button to toggle between viewfinder and monitor.
2. Does it mean it changes viewfinder / monitor right away with the press of that assigned button or it goes to settings where it can be changed?And also if someone would be so kind and record one minute video of small things in a far background in 1080p 50 or 60 fps?
And hosting original file on google drive or any other place.
Thank You
0 REPLIES 0
