EOS R6 Mark ii internal rattle
Raym1716
I just received a new R6 Mark ii and with no lens attached there is a rattle from inside the camera when you move the camera. It sounds to be coming from the shutter / sensor. Is this normal?
1 REPLY 1
kvbarkley
There are two possible sources of a "rattle":  one is IBIS if the unit is off, the sensor may be free to move around a bit. The other is the orientation sensor to determine landscape/portrait.
