EOS R3 and EOS R5 -Erratic Focus Point
Zhaopian
Enthusiast
Hello Folks,
In the last two days, I noticed something that I am seeking advice on.
Today, I photographed a boxing tournament using both my R3 and R5, and there are far too many pictures where things other than the boxers were in focus. At least among the 200+ good photos I got, the AF point is on target 98 percent of the time--although the fighters could be a bit more tac-sharp. While I could get right up on the ring, I wasn't leaning on the platform where I could have totally avoided the ropes, as I imagine professional boxing photographers do.
Yesterday, I was photographing a class and for the most part, the subject(s) was standing still. The problem was, the AF point would too easily bounce to something that was physically closer to my camera than the subject was (pole, table, plant, a student, etc).
I finally got good, or so I thought with Back Button Focus, so I am a bit perplexed as to why I can't truly lock on the subject. I'm fine if something comes between my camera and the subject that draws the focus point to it, but I should be able to reacquire the target/subject (ie.: the referee blocking my line of sight to the player). Instead, what I found was all too often, the AF point just wanted to stay on the thing that was closer, and I dare say on an entirely different geometric plane, of sorts, than the subject or rather the subject's face/eye.
So, should I use a bigger focus zone for non-portraits where the person is moving slightly? Should I use Single Shot instead of Servo for non-portraits yet people that are posing? Am I correct to avoid "eye detection" in sports where the players are either wearing helmets or they just jump around too much such that available eyes are few and far between? I also do not honestly think one tracking mode is overwhelmingly better than the other--we all have our favorites, so I don't think choosing the right mode is the be-all, end-all. But what else should I be doing that I'm not. Oddly, enough I also shot a parade the other day, and there were plenty of really good, tac-sharp photos I got of folks milling about, walking, or doing anything but hard 100 percent static posing or fast, erratic movement.
So, what gives? Thank you.
7 REPLIES 7
HorseSports
Same.  I have the R3 set to center focus, yet today the focal point jumped to the far corners repeatedly while I was photographing a sports event.  I've lost a lot of income on this one.
Try disabling Touch Focus/Shutter on the rear screen.  Even better, close it when you’re not using it.
Waddizzle
I finally got good, or so I thought with Back Button Focus, so I am a bit perplexed as to why I can't truly lock on the subject. I'm fine if something comes between my camera and the subject that draws the focus point to it, but I should be able to reacquire the target/subject (ie.: the referee blocking my line of sight to the player). Instead, what I found was all too often, the AF point just wanted to stay on the thing that was closer, and I dare say on an entirely different geometric plane, of sorts, than the subject or rather the subject's face/eye. “
If you’re photographing still subjects then you should probably be using a single AF point with no tracking, and One Shot AF
Also, the most common reason for the selected AF point to change and jump around is brushing against the rear screen as you raise the camera to your eye, or even between shots.
The rear screen has Touch Focus/Shutter.  You should disable it if you’re not using it, or keep the display closed.
BBF doesn’t change how well the camera focuses.  Some users feel using BBF gives them better control over selecting and acquiring a subject, especially moving ones.
My back screen is closed.  Last weekend while photographing in AI Servo with center focal point selected, the focal point again bounced all over the place requiring me to continually press the large wheel button to return focus to the center.  This is incredibly annoying.  This same issue happened at a paid event causing loss of income due to out of focus subjects.  I'm tracking using the shutter.  Help would be appreciated.
HorseSports
Still having issues with focal point jumping around while tracking or even photographing still objects.  Center focus is selected, and LCD screen is closed.  Eye control is off.
stevet1
On my camera at least, if I choose any of the Zone AF focus modes: Zone AF, Large Zone AF, or Whole Area AF, the focus will jump to the nearest subject.
If you are using one of these methods, try taking it out of the Zone AF and just use Single Point.
Steve Thomas
Still having issues with focal point jumping around while tracking or even photographing still objects.  Center focus is selected, and LCD screen is closed.  Eye control is off.  ”
You should tart a new thread of your own.
Friends and Family
