11-11-2024
09:11 PM
08:08 AM
Hello, I bought an EOS R100 kit with the RF-S18-45mm F4.5-6.3 IS STM and RF-S55-210mm F5-7.1 IS STM lenses. Can anyone recommend a user guide or video for someone new to the camera?
11-13-2024 04:01 PM
Ok nice! You'll want to optimize the camera for landscape. Usually that means having a large depth of field.You can do this manually or let the camera handle it - https://cam.start.canon/en/C015/manual/html/UG-02_BasicShooting_0060.html. You may also want to tweak color settings- https://cam.start.canon/en/C015/manual/html/UG-06_Shooting-1_0140.html
If you want to focus on an animal in the scene you should use focus tracking, especially if they're moving. https://cam.start.canon/en/C015/manual/html/UG-04_AF-Drive_0030.html
Also add servo AF- https://cam.start.canon/en/C015/manual/html/UG-04_AF-Drive_0020.html#AF-Drive_0020_2
11-20-2024 04:15 AM
Hi and welcome to the forum:
As regards coming to grips with your new camera, to add to the excellent offerings from my colleagues, you may want to check out some of the following tutorials:
(1) mavin eos r100 tutorial - YouTube
As a wildlife photographer myself, I suggest that for a safari trip, you contact the organizers and ask them what kit you should be using. Not long ago, I coached a couple who went on safari and from the photos they returned with, they were taking many of their shots in the 600mm range and above. Frankly, I suspect that with the gear you have it might be better to rent a separate kit and look at something like an EOS R6II and the RF 200-800, or the Sigma 60-600s. Your RF-S 55-210 is likely to be way short for many opportunities.
11-11-2024 10:49 PM
The user guide is a great place to start. Start by reading it. This is the best way to become familiar with your camera's features and operation.
https://www.usa.canon.com/support/p/eos-r100
There are a good number of YouTube videos as well.
https://youtu.be/afvznlES6i4?si=8FYjXB2Lj7IU7ca9
11-12-2024 12:47 AM
I too recommend youtube as a good place to start. Search for "EOS R100 setup", "EOS R100 for beginners" or similar phrases.
What are your favorite subjects? That will help determine what you should learn about first.
11-12-2024 11:07 PM
I want to get good at taking pictures of nature and animals in their natural environment. Specifically, beaches, forests, trails, desert, mountains, etc.
11-13-2024 04:01 PM
11-19-2024 09:24 PM
Great, thanks! I am heading on a safari trip and will use these tips.
11-20-2024 01:05 AM
For a safari, you will need something longer than a 210mm, even with an APS-C camera.
11-20-2024 04:15 AM
11-20-2024 07:32 PM
I am just going to work with what I got as a novice, however for future trips what would you recommend?
11-20-2024 07:34 PM
Thank you
