EOS 90D errors from Tamron lens at high angle
codegen
I have a G1 Tamron 150-600 that I bought 8 years ago when I had a T2i, now shooting a 90D. When I use it for birds, even pointing up into a tree (mostly hand held, occasionally tripod) it works fine. However, when I shoot the sun (with a solar filter) I get about two shots and then I get an error communicating with the lens, and I have to remove the camera and reattach it to the lens. I'm using the tripod mount on the lens, so there should not be much stress on the camera lens mount (the 90D is not a heavy camera). I never got that error with the T2i. Any Ideas?
What might be immediately helpful is testing the lens on another body.
What type of filter are you using with the lens? (please be specific)  since your post indicates you only get the error when pointing the lens at a bright light source.
I believe this is your lens:
SP 150-600mm F/5-6.3 Di VC USDA011
 Last FW was 2-19-2019.  For A011 G1 variants, the lens has to go back to Tamron for Updates.  Its not Tap-In compatible.  Doesn't look like it includes anything for the 90D, except for the LiveView Update.  Is this problem occurring during LiveView shooting?
FW for 2-19-2019
Service for compatible with Canon EOS R New firmware version makes the model compatible with Canon EOS R series cameras (*1) and Canon "Mount Adapter EF-EOS R" for general operations(*2).
(*1) Compatible cameras: EOS R / EOS RP / EOS R5 / EOS R6
(*2) Functions used on DSLR cameras February 19, 2019
Service for adding the Live View AF feature In combination with the Canon EOS 8000D, EOS Kiss X8i or any later camera model, the AF feature will operate properly in the Live View shooting mode.
* Among the supported lens models, those for which production is discontinued are not listed.
Service for adding the panning feature The lens will be used for panning when the VC camera shake compensation mechanism is active.
You'll have to determine if there is any correlation between the Comm error and LiveView.  I'm not a Tamron user, so maybe others can add to the conversation.
9 REPLIES 9
FW for 2-19-2019
codegen
That is indeed the lens. It has never been updated. I wonder how much it would cost given the lens is 8 years old.
I am using LiveView, but with Manual Focus (There isn't really much detail that the autofocus could lock on with the solar filter). I am using VC, may be I should try turning if off since I'm using the wired remote. The solar filter is a Kendrick 6004-sf  https://www.kendrickastro.com/solarfilters.html.  The one with the three tabs as opposed to the full collar (illustrated just above the table that contains 6004-SF. Unfortunately, I gave by T2i to my brother (2000km away) so I don't have a second body to test with. Example photo below, the sun that day was mostly featureless with some small sunspots on the left limb of the sun.
Have you downloaded the Tamron Lens Utility SOFTWARE or TAP-in Utility to see if it will update? It looks like that are free.
Marc
Windy City
Great minds discuss ideas; average minds discuss events; small minds discuss people. Discussion is an exchange of knowledge; an argument an exchange of ignorance
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
The G1 doesn't have a USB port on them for the Tap-in. Too old.
March411
That would be the problem. I am unfamiliar with that lens but no port would kind of be a hard stop.
Good luck tomorrow!
Marc
Windy City
Personal Gallery
@codegen,
I'd try and get through tomorrow as March411 suggests.  If you plan to keep the lens, I'd get it to Tamron for inspection and the 2019 update.  It will increase the re-sale value should you ever decide on that.  It will also improve LiveView and VC operation (with DSLRs).  Most importantly it provides compatibility with a R series body and EF to EOS-R adapter (Which Tamron claims).
Thanks.
codegen
Looks like it was the live view. If I use the live view to focus and centre the shot, and then turn it off, the shots work perfectly. I also had VC turned off as well.
Thanks for the help.
kvbarkley
I was going to say, I have never had an issue.
