12-13-2024 11:15 AM - last edited on 12-13-2024 11:39 AM by SamanthaW
I presume, or hope, it is a setting. I can't see through the lens on my D90. I can see on the display, but not through the lens. Plus, either way, the little button you push to make a picture doesn't work right. Even when I'm looking at the display, I can't take a picture. Any help?
12-13-2024 12:17 PM
Turn the camera on with the lens off. If the mirror goes up then live view or movie mode is more than likely on. This prevents viewfinder operation.
12-13-2024 11:24 AM
Hello!
So that the Community can help you better, we will need to know more information.
Which exact Canon Camera and Lens are you using and having issues with?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks and have a great day!
12-13-2024 11:32 AM
It is a D90. I've tried various lens. This is my first camera with the lcd screen. If the camera is turned off, I can see through the old viewfinder. When I turn it on, I can only see the image on the lcd screen. AND, the "take a picture" button doesn't work either way.
12-13-2024 11:35 AM
And the lens?
12-13-2024 11:37 AM
Various lens. The one now is the 24-105 IS
12-13-2024 11:39 AM
But I've tried several others. My 35-350 doesn't work, either.
12-13-2024 12:02 PM
Take off the lens with the camera turned off. Is the mirror up or down?
12-13-2024 12:10 PM
Not sure if it's up or down.😁 But it is in the same position as the mirror on my old 7d, which is working fine
12-13-2024 12:12 PM
And with the lens off, I can see through the viewfinder ok.
12-13-2024 12:17 PM
