07-28-2020
11:22 PM
08:01 AM
I have tried using webcam utility software with my caon eos 80d, while connecting after few seconds it shows the error 70 and the camera stops working, i have tried removing battery and again starting the webcam utility but it again and again showing the same error.
01-15-2021 03:02 PM
I assigned all my preferred settings to the C2 slot, and use that instead of any other of the shooting modes (I'm assuming C1 works as well) and the Err 70 goes away.
02-03-2022 05:56 AM
I've had the same problem too.
This Thread is a bit older now but there is not much information in the internet about that specific problem.
I was able to solve the problem by changing the mode from manual to P. I think you can use automatic mode too. Now it works as it should. Maybe there is a problem with the combination of shutter, ISO and aperture the webcam utilities can't handle.
