09-22-2020 06:30 PM
09-22-2020 08:25 PM - edited 09-22-2020 08:35 PM
Every day you are without a camera when you are traveling is a day lost, so I have a couple of suggestions:
Can you still see a display in the viewfinder? If it is still working then I would suggest use that to expose and frame your shots (generations of photographers have not had an LCD and did absolutely fine).
If you have a suitable smartphone you should be able to monitor and control the camera via that, using the Canon Connect software that you can download off the web.
Once you get home, and can stick around to get a reputable tech to check out your camera, then you can decide what to do. Since the camera is a relatively new model, you should be aware that trying to fix it yourself will void any warranty, whereas while you will likely have to pay for this repair, if it is done by an authorized repair centre, your warranty should be maintained.
@garuda wrote:
Hi! I had an unfortunate accident last night and my EOS 250D had a hard fall onto a rock. When I picked it up the screen was blank, but still backlit. I tried taking a photo and it still shot fine with the settings I was using (timer and long exposure). I attempted to ensure it was just a cable that had shaken loose bt opening the screen part, but everything seems tight and the screen is still blank.
Essentially what I want to know is exactly where the issue lies and what needs to be replaced. If it's just the LCD, I feel confident enough to do that myself, but it's not clear to me that's the issue, since the backlight still works as expected, just nothing else shows up.
Any ideas for how I can determine the exact issue and/or how to fix it without sending it in (I'm currently traveling and would like it back in working order ASAP)? Thanks!!
09-22-2020 10:46 PM
09-24-2020 10:33 AM
Is that the same as the SL3? I think it is. The camera should go to Canon. A hard fall has most likely done more bad things inside. The LCD may only be a symptom. Canon will test everything and recalibrate everything when they do the repair.
