03-26-2025
12:41 PM
08:01 AM
Hello everyone!
I have a Canon EOS 250D camera, purchased a year ago. But the new camera has started to act the same my previous camera after what I did replace it.
It is quite hard to explain this problem but autofocus suddenly stops working as well as the display turns off. Live view button is not working also. Then suddenly it is back working but after several shots the problem returns. The only thing I see on display is the "Sensor cleaning" note when turning off the camera.
When i connect the camera to the pc with a wire, then the display works ...
What could be the problem? Don't want to buy another one so soon.
03-26-2025 01:29 PM
Are you using a 3rd Party lens or any other accessories attached to your camera. If so please list all of them.
03-26-2025 01:54 PM
Are you using the same batteries? The same lens? It could be a weak battery or a short in the lens.
03-26-2025 02:15 PM
I use Canon 70-300mm and Canon 50mm lenses. And that is all I use.
03-26-2025 02:15 PM
I have tried different batteries which are all original Canon batteries.
03-26-2025 02:21 PM
Which Canon 70-300mm and which Canon 50mm lenses. Canon has released multiple lenses with those names. A complete name would be Canon EF 70-300mm F4-5.6 IS II USM & Canon EF 50mm F/1.8 STM. Below are example pictures of how to find the lenses full name.
03-26-2025 02:25 PM
Canon EF LENS 50mm 1:1:1.8 STM
Canon ZOOM LENS EF 70-300mm 1:4-5.6 IS II USM
I also tried the kit lenses, the problem is the same with that one.
03-26-2025 02:40 PM
Have you tried a different body. Where did you get these batteries from. Are they 3rd Party or OEM batteries. Also what kind of memory card are you using Full Sized or Micro in an adapter. If an adapted Micro SD Card discontinue the use of it.
03-26-2025 02:58 PM
I am sure that the problem is with the body and not with the lenses. I use SanDisk 128GB Extreme Pro 200MB/s and it is a full size card. Have also tried another cards, the problem remains. The problem is somewhere in the body ... Batteries are original, one came with the camera and the other one is exactly the same.
03-26-2025 03:06 PM
Your particular camera model doesn’t work very well with large capacity SD cards. Stick with 32GB or smaller SD Card. Even though the manual states they’re “compatible” they’re not. They often cause problems with locking up or hanging.
