09-19-2023 04:18 PM
I've done everything with respect to trying to get this camera to turn on. I've tried removing the lens to make sure that the connectors were working properly, made sure I had a fully charged battery in the camera, bought and replaced the SIM card, ensured that the battery door was closing well in order to make sure it was activating the sensor, and lastly I clean the battery compartment's connector down at the bottom to ensure that there no debris in there. I'm at a lost as to why all of a sudden the camera will not power up.
09-19-2023 04:30 PM
You probably need to send it in, or:
09-19-2023 04:35 PM
When you say "SIM card" it leaves me wondering if you're using a Micro SD card with an adapter. These can be problematic and may cause erratic behavior. Canon's recommendation is to use only the correct full size SD cards. And consider using a genuine, name brand card (Lexar or SanDisk from a reputable vendor) of maybe no more than 64gb or so.
09-19-2023 04:43 PM
32GB or smaller SDHC Cards work better with lower end cameras. For some reason larger capacity 64GB or larger SDXC Cards cause problems with these cameras. Even though the manual states that those cards are compatible.
09-19-2023 05:37 PM
Yes, I’m using a full size SD card not a micro
09-19-2023 05:45 PM
Remove the lens and SD Card to see if the camera will powerup if you have a spare battery try using it in the camera too.
09-29-2023 08:59 PM
Hi BurnUnit, i have the same issue, my brand new camara died after a few minuts of use, BUT i was using an old micro SD card, i try to reset it by taking all accessories out and pressing the shooting button but didnt work, what do you recommend me to do? its new i haven’t dropped it or damage anything :C
09-29-2023 09:06 PM - edited 09-29-2023 09:07 PM
Did you charge the battery? Only use a full size SD card, not a micro SD card.
09-29-2023 10:15 PM
the battery is full charged i already try 2 diferent batteries , i try to turn it on with out any SD card but doesn’t respond to anything
09-29-2023 10:28 PM
It appears that it needs to be sent in for warranty or replacement.
