Canon EOS 7D Battery drain Issue
isad008
Hello,
Last week I bought a new Canon EOS 7D body. Before starting to use the camera for the first time I fully charged my battery and started using it. I used the camera for one week. I shoot raw with back display always on and LCD brightness to very low. I took around 200 images, 10 with live view mode and 2-3 image with flash and a 30 sec video and my lens is 24-105 f/4 L. I turn off the camera when not in use.
But after 200-250 images my battery just rans out of juice. According to canon, the battery supports up to 1000 shots with fully charged battery. I don't use flash at all and I did mostly indoor shoots. What I feel like is my battery is draining pretty fast. Seems very unusual. After facing this issue I tried to find out how fast my battery was draining. So I shoot 3 raw images and found that battery just drained 1% so I keep doing it and eventually found that each 3-4 images taken my battery loses 1% of charge. I can only take around 220-280 images with a fully charged battery.
Super disappointed  :(
I hope any Canon 7D user could shed some light with this matter. Let me know if I am doing anything wrong here. Thanks in advance.
"Life it self is a mystery, Shoot everything"
Canon - 7D, 600D/T3i
Canon - 24-105mm F/4 L, 50mm F/1.8 Mark II
MY FLICKR
37 REPLIES 37
roderickruiz1
I'm having the same problem.  I just got my new Canon 7D Mk II 2 days ago and I did what most excited photographer would do is to charge up that battery.  But low and behold, after a couple of experiments on the battery issue, the battery is discharging even when the camera is off by 10%-25%.  This is terrible.  I hope Canon can fix this.  I love this camera.
Rod.
Shut off the GPS.
roderickruiz1
Like I said, I did all of that specially the GPS.
You wrote that you did shot off the camera, not GPS.
What about another battery? Same issue?
What about other lenses or without a lens? Do you use a Tamron 24-70?
roderickruiz1
I only tried it with my old Canon 7D Battery to set up the Camera while the new one was charging. But that's about it. Then I swap the new one in once the charging was done.
roderickruiz1
I use the Canon ESF 17-55 and yes I turned off the camera and disabled GPS.
So try without a lens and also try your older battery.
roderickruiz1
I will and I'll let you know tomorrow.
Thanks.
Something new about this?
roderickruiz1
There was something wrong with the battery so I went and bought a new one. Now its perfect.
