09-29-2023
01:01 PM
01:36 PM
Hello Everyone,
I've been looking to replace my EOS Rebel T5 with a Canon 90D because I really need a new photo for sports photography. I guess I can start with if the 90D is good for shooting sports photos at night and indoors. I've also seen mixed answers as if my current EF 70-200mm 1:2.8 L IS USM lens will fit onto the Canon 90D. I thought I saw any EF lens would fit, but will I have to worry about bad results if I'm using this lens?
09-29-2023 01:17 PM
The 90D is the last and the best crop model DSLR Canon has made or will ever make. It is a superb camera.
Your ef 70-200mm f2.8L will not only work on a 90D bit it will show its stuff as the 90D has an excellent sensor. It has 32 mp which a lot a whole lot! My personal choice for a 90D is to pare it with the Sigma 18-35mm f/1.8 DC HSM Art Lens. That combo will not take a back seat to anything.
09-29-2023 01:09 PM
Hello there!
The EOS 90D will fit EF and EF-S lenses!
Hope this helps! 🤗
09-29-2023 01:17 PM
09-29-2023 01:40 PM
Thank you!!
09-29-2023 01:41 PM
Thank you very much!
11-10-2025 04:24 PM
Just so people now. The EF 70-200mm f2.8L (version1) doesn't work real well at full zoom (200mm) on the 90D. If you have a Canon 90D and want a 70 to 200 lens. Make sure you buy a version 2 or 3 of the EF 70-200mm f2.8L.
11-10-2025 04:28 PM
11-10-2025 02:24 PM
11-11-2025 11:49 AM - edited 11-11-2025 11:51 AM
"The EF 70-200mm f2.8L (version1) doesn't work real well at full zoom (200mm) on the 90D."
Where did you get that nonsense? The EF 70-200mm f/2.8L is an EF lens and is fully compatible with the 90D.
All of the versions of the ef 70-200mm f2.8L's are optically very similar. The main difference between ef 70-200mm f/2.8L version 1 and version 2, 3 are coatings. Like Canon's Air Sphere Coating for reduced flare and fluorine coating on the front and rear elements. And of course the new white paint.
